Corian For Threshold - Flooring - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 12:54 PM   #1
Just call me Andrew
Rewards Points: 1,020
Corian for threshold
I am building a custom shower. I want a piece of stone (or corian) cut up for the threshold into the shower, the main bathroom door threshold, and some recessed shelves.
Is corian OK to use? I am thinking in particular the pieces that will be walked on. Is it as strong as granite or marble? What's the ideal material to use that would work in a wet area and also hold up when walked on?
This all depends on finding a remnant I like at a stone fabricator...
Andrew
secutanudu is offline   Reply With Quote
Old 05-10-2010, 05:02 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Corian (or any solid surfacing material) works great. Walking on it in a bathroom shouldn't be an issue unless you are used to taking a shower while wearing you golf shoes or combat boots.
Corian is not as hard as granite but not much is. We use Corian shelves and curb covers and bench seat covers frequently in showers. Not a problem!
XXX
Old 05-10-2010, 05:32 PM   #3
Thresholds are usually of some hard material.
I'm not sure what qualities Corian is designed to have [I think it is in its 28th version].
http://www.google.com/search?hl=en&s...k&ved=0CBQQgwM
http://www.google.com/search?hl=en&s...rinell&spell=1
Old 05-10-2010, 08:34 PM   #4
DIY staff
Rewards Points: 7,174
Corian is a fine product to use ----Go for it.
Old 05-10-2010, 08:37 PM   #5
Just call me Andrew
Thanks!
Andrew
Old 05-11-2010, 11:52 AM   #6
Hi Andrew, You can contact a Certified Fabricator Installer to determine if this can be done within DuPont guidelines so that warranty coverage is maintained. You can get the name of a Certified Fabricator Installer through the Authorized Distributor in your area. Call our 800-426-7426 number for an Authorized Distributor. For more info on DuPont(tm) Corian(r), feel free to visit us at www.surfaces.dupont.com.
Good luck!
Christine, DuPont Building Innovations
cpjohnson is offline   Reply With Quote
The Following User Says Thank You to cpjohnson For This Useful Post:
secutanudu (05-11-2010)
Old 05-11-2010, 01:35 PM   #7
Good luck!
So, what are the design goals for Corian?
In a Berlin museum they made a scale model of a building out of it, so it must be machinable.
Old 10-12-2010, 01:22 PM   #8
Corian
Bud,
What do you use to make the corian adhere to the curb and do you leave any overhang of the corian? Also, have you ever used the corian for the sides of the door jamb of the shower instead of tile?
nolfj is offline   Reply With Quote
Old 10-12-2010, 03:01 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Bud,
100% silicone caulk.
Bud,
Yes, usually about 1/4" to 3/8".
Bud,
Yes, occasionally.
XXX
Corian sinks--need advice! Asap! Please! donnatella General DIY Discussions 10 05-15-2011 11:37 AM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 07:18 PM
corian counter tops GailMae Remodeling 4 07-22-2009 11:47 AM
How can you cut a piece of Corian coutner? Sephora Kitchen & Bath Remodeling 3 05-06-2009 07:54 AM
How to cut corian countertop for a sink apt238 Building & Construction 7 10-21-2008 01:28 AM
