Coping Baseboards - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2009, 05:16 PM   #1
Rewards Points: 51
coping baseboards
I'm having trouble coping my inside corners on my baseboards. The videos made it look so easy, and like they would come out perfect- unfortunately, not so easy, and my edges have gaps and, well, look like an amateur did them (what a surprise...). If anyone has any tips for me, it would be much appreciated.
preciouschristy is offline   Reply With Quote
Old 09-06-2009, 07:56 AM   #2
I'm doing my baseboards now and coping the ends. First measure the piece you need and cut ends at 45 degrees that you want to cope and take a coping saw and follow the profile on the edge with the 45 degree and it will be perfect. Not to complicate things, after I cut my 45 degree I turn the piece upside down and use the miter saw to cut up to where you need to use a coping saw. This just makes it faster instead of using the coping saw to cut the staight lines. Hope this helps
hrjrkr is offline   Reply With Quote
Old 09-07-2009, 10:04 AM   #3
Remodeling Contractor
most likely you problem is that most all corners are not a perfect 90. So the 45 degree cuts are incorrect to start with. There are many attachments and guides available to help. basically you just need to back cut at a slight angle using a jig saw and fine tune with a rasp or sandpaper.
Old 09-08-2009, 04:53 AM   #4
Cutting the baseboard at a 45 is just a guide to cut the lenght you need and to cut the profile of the baseboard with a coping saw. It does NOT stay at a 45. I did my whole house this way (with Red Oak) and it came out perfect.
How Best to Paint Baseboards in Carpeted Rooms? biggles99 Painting 22 04-17-2011 06:44 AM
1st post 1st project baseboards color question 7roses Painting 13 06-30-2009 05:46 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 05:52 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
