Old 08-30-2011, 08:45 PM   #1
contractor installing vinyle with baseboards on still
Is it correct that if installing vinyle with baseboards that they would have to leave 1\2 inch opening between the baseboard and the new vinyle.
djsmith1969 is offline   Reply With Quote
Old 08-30-2011, 08:53 PM   #2
Super Moderator
No--you are thinking of hardwood which needs expansion space,
Sheet goods can be cut tight and attached without issues.
If I'm wrong someone will set you straight.--Mike---
Old 08-30-2011, 08:59 PM   #3
Tileguy
JazMan's Avatar
There's no reason to remove the base boards for vinyl installations, just the shoe molding. It's a good idea to leave a little space maybe 1/8-1/4". You definitely don't want a 1/2" gap though. Is it really that wide? The shoe molding will just barely cover that.
Did you think they should have removed the base?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 08-30-2011, 10:14 PM   #4
Pro Flooring Installer
rusty baker's Avatar
The vinyl backed vinyls (like IVC) require 1/8" gap around all obstructions. Felt backed vinyls can be cut in tight
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Baseboards before or after skimcoat? BagOfMostlyWate Drywall & Plaster 5 10-23-2010 09:43 AM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 12:25 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 06:52 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-31-2008 12:03 AM
