Continue Hardwood In Living Room... - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 04:06 PM   #1
Rewards Points: 1,030
Continue hardwood in living room...
Hello
I bought a house where the previous owner had hardwood floor installed in the dinning room, but not in the living room where there is still carpet
I thought it would be relatively easy to remove the carpet and continue the installation, but i realized the planks were laid down with the groove facing the carpeted area....
Meaning i can't simply continue the installation from the dinning room, since the tongue where the nails are going won't be oriented toward the living room
What are my options? does that mean i will have to put a threshold bar in between?
french_guy is online now   Reply With Quote
Old 05-12-2013, 09:25 PM   #2
woodman58's Avatar
Find a local floor store and have them order slip tounges (spines). The spines go in the grove and then you will be able to install the new wood. If you can't find splines you can make your own with a table saw. Cut the thickness first then the width to fit the boards together.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 05-13-2013, 03:37 PM   #3
I found in the basement 1 roll (left over I guess) of pink paper
So I assume this is what was put underneath the hardwood in the dinning room (Bruce #76336 - 3 1/4" x 1/4") as underlayment
Is this a good choice, or should I go for some roofing felt (15lbs or 30lbs)?
Old 05-13-2013, 04:01 PM   #4
Rewards Points: 150
Sounds like rosin paper. I guess that's fine if you're not concerned about moisture. I liked using Aquabar underlayment. The water resistance of roofing felt without the mess and weight.
Splines turn a groove into a tongue. Just wood glue them in (some like to use finish nails, too). A flooring store or mill should have them. Much cheaper from the mill - I paid $1 for 3 ft spline lengths. Dunno what a flooring store would charge, but as a price comparison a flooring store wanted $40 for a hardwood reducer for which the mill charged $7.50. I just made my own out of disgust.
zakany is offline   Reply With Quote
Replacing carpet in living and dining room. Need advice! mandingo Flooring 2 02-24-2012 12:41 PM
Need ideas for large, multi-space living room D-Lew Interior Decorating 2 01-03-2012 01:26 PM
Installing hardwood in sunken living room alupso Flooring 3 07-20-2010 12:33 PM
need new Living room layout, very confused fox_forma Interior Decorating 14 03-17-2010 09:26 AM
Suggestions for Living Room gante Interior Decorating 3 03-06-2009 12:56 PM
