Congoleum Vinyl Flooring Dirty All The Time - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2013, 08:33 AM   #1
Rewards Points: 101
Post
Congoleum Vinyl Flooring dirty all the time
We put Congoleum Vinyl Flooring down 6 years ago and each time you clean it , still dirty. You can clean or wash it 3 or 4 times one after the other and it is still dirty.
I don't know what I have to do to get it clean, it's been like this ever since we have had it.
Wrote Congoleum and they never returned any answer. It was there best Vinyl Flooring.
Can someone please tell me what to do.
Should I put polish or wax on it?
nhoj is offline   Reply With Quote
Old 12-17-2013, 09:00 AM   #2
Rewards Points: 12,856
Most likely it has nothing to do with the flooring, it's what's under it.
What was it laid over.
If it was louon, then that's it.
It has not been approved for many years as an underlayment.
It has voids, can cause glues to release, and in your cause color bleed through.
Why is it still for sale? Same reason you can still buy particle board, Cellotex, electroplated galvanized screws, people keep buying it.
Old 12-17-2013, 09:31 AM   #3
Rewards Points: 101
I got the underlayment from where I got the Congoleum Vinyl Flooring and he was in business for 30 years, so he should have known what to use.
Is there anything that we can do now?
What would cause this to come through?
I am not sure if it was this underlayment.
Old 12-17-2013, 09:51 AM   #4
Was a moisture test done before the underlayment went in?
How long ago was it laid?
This is what should have gone in.
http://www.halexcorp.com/underlayment_birch_4.shtml
It was common years ago to use louon, from what I've been told by flooring manufactures and read is most of it is imported, in order for it to be allowed into the county it had to be treated with pesticides which is causing some of the issues. The tannins in the wood are bleeding out.
Old 12-17-2013, 10:09 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Do not wax it. Wax or polish will make it duller, vinyl has been no wax for many years. Go to a carpet store, not a big box, and buy some Congoleum vinyl floor cleaner. It should restore the shine.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-17-2013, 10:52 AM   #6
Rewards Points: 101
I know for a fact now that it was 1/4 inch plywood that we used.
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-05-2012 12:09 AM
vinyl over vinyl flooring ri98 Flooring 3 11-08-2011 09:00 PM
?laminate or allure vinyl plank flooring? suevwbug Flooring 0 05-09-2011 10:26 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 06:20 AM
