-   -   confusion over thinsets for installing Ditra over heated flooring (http://www.diychatroom.com/f5/confusion-over-thinsets-installing-ditra-over-heated-flooring-34851/)
fhknox 01-01-2009 12:39 PM
I am preparing to install Ditra over thin-wire heated floor heating, which in turn will be installed on a plywood substrate.
My confusion is whether I need to set the heted flooring in modified thinset as per the instructions, and let it set before I lay down the Ditra. If so how long would it be necessary to allow for setting before putting down the Ditra. If this scenario is the case, then would I now need to use unmodified thinset to adhere the Ditra to the previously set modified thinset?
If there is no need to effectively have the two layers, then is it safe to assume that the modified over the wire heating on the plywood is correct to apply to the Ditra?
Thanks for any help, that may relieve some of the confusion.
Just Bill 01-01-2009 05:27 PM
Regardless of what you read here, ALWAYS follow manufacturers instructions. I am sure they cover your situation there somewhere. But since you are using a product designed to cover breaks, I would use modified thinset.
angus242 01-01-2009 05:58 PM
Yes, set the heated mat or wires in modified thinset and let cure as per the instructions on the bag. Then install Ditra using non-modified thinset.
That's the instructions per Schluter. You can technically use modified for the entire process BUT you void the Schluter warranty and dramtically increase the curing time for the thinset under the Ditra.
I'd stick to the instructions as per the manufacturer! :yes:
JazMan 01-01-2009 11:33 PM
The main question is; are you spreading modified thin set on the entire plywood floor in order to install the heat wire? If so, you should use un-mod to install Ditra because its substrate is thin set, not plywood.
If part of the plywood remains bare, or if the wires and Ditra get installed in one process (unlikely), then you'd have to use modified in order to get anything to bond to plywood.
Jaz
poppameth 01-02-2009 10:34 AM
You'd be better off using a self leveler for the heat instead of thinset. Then use unmodified for the ditra.
Karde 01-04-2009 07:52 AM
Since he is installing this on plywood, won't he have a problem with the self-leveling cement unless he uses lath?
Bob Mariani 01-04-2009 08:03 AM
Do not use self leveling cement. Not really level either. Jazman states to use modified to bond to plywood. BUT... non-modified is recommended by the TCA because it will not bond to the plywood. This is what you want. The plywood can shrink and move. The non-bonded area above (wire, thinset, thinset tile) will not move. Thus not crack. So to be clear... non-modified first. Modified for flexibility next to set tile.
Karde 01-04-2009 09:53 AM
Would you expect getting a level surface over the wire with non-modified thinset to be very difficult?
JazMan 01-04-2009 10:30 AM
Bob,
You've got it backwards and maybe you're not familiar with what Ditra is? You must think Ditra is a CBU and not a membrane?
Jaz
Bob Mariani 01-04-2009 10:39 AM
yep. that is what I was thinking.. oops.
Bud Cline 01-04-2009 11:05 AM
HOGWASH!
Exactly how many heated floors have you personally done Bob? Really: How many?
poppameth 01-04-2009 11:46 AM
There are several self levelers that work just fine over plywood. Some require a thicker pour than others. You just have to be careful which one you choose.
diy888 01-19-2009 06:21 PM
My master-bath plywood substrate is flat but has a bad slope: more than 12mm (1/2") over 8 feet. One corner is 18mm (3/4") lower than the highpoint.
I used WEDI on the walls and WEDI Fundo as shower base (shower was on a perfectly level section of an adjacent alcove that was made part of the room) and I am trying to decide what to do about the floor.
It cannot be leveled with SLC only because the threshold is on the low end of the room and the plywood is already 1" higher than the bedroom's floorboards. The SLC pour plus mesh plus tile would make it 2" higher. But I can forget about leveling and hide the slop behind the vanity.
Also, I want to use something like Ardex Feather Finish to smooth out 1-2mm differences in height between adjacent plywood panels on the substrate.
What type of uncoupling membrane should I put on top of this plywood + Ardex Feather Finish?
(there are two layers of plywood, each 3/4" thick; 10" joists 16" o.c.; unsupported span 10')
Wedi 1/4" panels?
DITRA?
Something else?
And what kind of thinset if there will be bare plywood and also patches of Ardex Feather Finish at the joints?
