Concrete Or Wood? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 11:19 AM   #1
Concrete or Wood?
Hi folks
I am converting an old outhouse into a wet-room and putting a sauna and shower in it. Question is do I build a wooden floor or a concrete one?
The wooden floor has been recomended as it gives a good flat finish, some more insulation and I can easily locate the drainage from the shower. But I'd heard contrary advice that it will rot from beneath sooner or later, even if a damp proof layer is put over the ground and rubble where the floor is being laid, and the joists are also protected from damp.
So am I better with a concrete floor?
In either case I plan to put a heating mat down and then ceramic tiles on top of that.
Any comments and advice much appreciated!
shimmy is offline   Reply With Quote
Old 02-07-2010, 07:41 AM   #2
Rewards Points: 4,656
use gulf ucf & be done w/it !
[ no financial interest ! ]
Tags
concrete , floor , wood
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 10:10 PM
