Concrete Subfloor Not Level - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 02:19 PM   #1
concrete subfloor not level
Hi there,
Has anyone had any experience laying Pergo snap 'n click laminate flooring over concrete subfloor that was NOT level? This is our situation and we have begun to chop out portions of the concrete floor that are the worst off, but we know we wont' be able to get the whole thing perfect and cannot afford to throw down self levelling compound over the entire 800 square feet.
How much leeway do we have and can anyone share tips for how to remedy this?
AnnaVanLenten is offline   Reply With Quote
Old 10-08-2008, 02:51 PM   #2
There is not a lot of leeway on putting this over uneven flooring. It has to be pretty level.
This type of flooring can bridge small indentations so breaking up the high points is not a bad idea.
If the floor is not above anything else you could pour a thin layer of water to see where the high points are. Be very careful so that the water doesn't extend to other parts of the house. Caulking the concrete/sill plate joint will keep the water in.
I have done this in several homes and it works well. Once I get the high spots hammered down I removed the water with a wet vac.
Then I put down the flooring.
If you have sheetrock to the floor then this is not an option (and really sheet rock should never be touching a concrete floor).
You can also get some leveler and level the areas that are the worst. The laminate flooring can go over gradual ups and downs that are far apart. What the term far apart means is too difficult to describe in an on line forum but I would say no more than a 1/32" change per foot (just guessing here).
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-23-2008, 01:21 AM   #3
Level vs flat
The floor must be flat for the flooring to fit together properly. I used Planipatch (Lowes) to fill in the low spots on my concrete slab.
Gevans17 is offline   Reply With Quote
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 01:41 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
