Concrete Staining - Flooring - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 12:14 PM   #1
concrete staining
I am getting my floor ready to stain but I need to get paint off of the conrete before I do so. How can I remove the paint from the conrete (the floor is inside
goodgolly is offline   Reply With Quote
Old 02-10-2010, 07:37 PM   #2
Removing paint before staining
There are several ways you remove the paint but whatever you do if you are planning on using a concrete acid stain don't use muriatic acid to clean the floor. Franmar.com carries a product called SoyGel that is excellent for removing paint. It is manufactured with soy bean esters and is therefore both eco-friendly and safe to use.
The second method would be to pick up some Citrus Strip from Home Depot or Lowe's, it is a citrus based product and safe to use.
The third method would be to scrub the flooor with a black pad and a floor buffer and it might be necessary to put a sandscreen under the buffer pad. A sandscreen is similar to what they use to sand drywall with but it comes in 17" round screens that won't scratch the concrete surface.
Hope this helps
Stain Wiz
Stain Wizard is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Cleaning concrete for staining Shanna Flooring 6 03-19-2011 01:34 PM
Staining concrete flooring - questions on cleanup and relief cuts vseven Flooring 3 12-15-2009 08:07 AM
q on staining concrete - pretty basic, best subforum I could find.. joeyboy Painting 2 10-29-2007 12:39 PM
acid staining concrete? trying-austin Flooring 1 02-18-2007 10:42 AM
