Old 10-18-2009, 01:44 AM   #1
Default Concrete slab question
I have a home which is on a slab, no basement or crawlspace. Under normal circumstances, is there supposed to be any type of subfloor material laid on top of the concrete slab before carpet/padding is put down, or [any type] of tile is laid?
mudpaws is offline   Reply With Quote
Old 10-18-2009, 09:12 AM   #2
both tile and carpet can be applied directly to the slab providing the slab is and will remain dry.
Old 10-18-2009, 09:38 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Hello MUDPAWS its been awhile .As bob stated above you should be fine as long as the slab is dry. How did your sheathing and siding project turn out.
More On This Topic
About Nail Gun Nails
About Nail Gun Nails by Expert Village
This is Rob McManhon for Expert Village. There are different types of gun nails that you use. These are for framing. They are 3 ¼ inches - it is 12 pending nail. These are more for siding or using thinner stock that it. 8 penny - 2 ¼ inches... Read More »
Hi! This is Elizabeth, and on behalf of Expert Village, we’re moving forward with creating a shaker card as part of our series of using beads in your cards. So what we’re doing is we’ve cut the window in the card. Now, we’re going... Read More »
This is Rob McManhon for Expert Village. If you are using narrower stock - this is ¾ and an inch thick, you want to use your narrower nails. Now this is the type of material that you would use for doing trim. Now you would put it over your rough... Read More »
This is Rob McManhon for Expert Village. Now that was just a eighth penny nail if you had a proper framing nail that would nail your fingers together. So you just have to be very careful. Another thing to pay attention to is not having the gun too close... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be renailing our siding. The areas on our siding that we took out are nails so that we could put that metal flashing up in there. We need to replace those nails so that the siding won't... Read More »
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 6 02-19-2009 11:42 PM
Poor quality concrete slab Phantom Flooring 2 05-22-2008 06:54 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 10:55 AM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 12:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 12:29 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
