Old 06-18-2009, 08:10 PM   #1
Lightbulb
Concrete Patio
I am needing some advice on some different ways to fix a sloping concrete pad. And yes it does slope back toward the house, causing water to leak in the basement around the perimeter of the floor. I have though about grinding the outside edge down to where the water would run away from the house and then seal and lay paver bricks over top. Not sure if this would work. Any and all ideas would be appreciated. Thanks to all in advance.
sassylady is offline   Reply With Quote
Old 06-19-2009, 10:42 AM   #2
gravity always wins
Concrete Patio
How big is the pad? How far out of level is it? What is the length along the house wall?
Old 06-19-2009, 04:22 PM   #3
Tileguy
Bud Cline's Avatar
Concrete Patio
Trough it!
Old 06-25-2009, 02:00 AM   #4
Concrete Patio
It is a 12' X 46' and it is up against the front of the house. It slopes back toward the house about an inch to inch and a half in ten feet. We have not put a roof over it yet, so it is open.
Old 06-25-2009, 02:17 AM   #5
Concrete Patio
What is this troughing and how is it done?
Old 06-25-2009, 07:17 AM   #6
ccarlisle's Avatar
Concrete Patio
You may be a candidate for "mud-jacking" or "slab-jacking", depending on how you name it in your part of the country.
Either way you call it, it is a service that lifts slabs by injecting grout, or cement, underneath the slab thus lifting it hydraulically. they drill 3/4" holes into the slab fro above, attach a truck-mounted pump to a hose and then watch the whole slab rise to where you want it. Cost effective against new slab, but it is comparable to repours...a lot of factors go into it, but it wouldn't hurt to have a company quote on that to tell you those options may be.
ccarlisle is online now   Reply With Quote
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Concrete Form for Raised Patio PerpetuallyRepairing Building & Construction 6 04-08-2008 07:33 PM
