Old 09-17-2012, 05:05 PM   #1
landlady
concrete patch preparing for drain
My laundry room concrete floor has a slight dip against part of a wall where washer and sink are and which is adjoining a finished room on other side. Any overflow or problem would send water in that direction. Where I would like to put a new drain (connecting to kitchen sink drain pipe under the floor) is in the other direction. Is it possible to just patch that slight dip or do we have to clear out whole room and level it?
mpower is offline   Reply With Quote
Old 09-17-2012, 11:14 PM   #2
the logical place would be in the low spot, if the floor already goes that way. put a pan under the washer and pipe that down through the floor.
Tags
concrete patch, laundry room drain
Preparing old concrete for paint Sibsmi Flooring 7 01-01-2012 10:15 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
