Concrete With Old Glue - Flooring - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 07:09 PM   #1
Question
Concrete with old glue
I have a room with an old concrete floor. We used a carbit buffer to remove glue. You can't feel it. I had a concrete guy lay some vinyl cement in some low areas. It looked good but then it did not bond to existing concrete. He has removed what he poured and dosn't want to risk material & time to try again. So I am also concerned about the paint or stain adhearing. Any cleaning suggestions that arn't crazy involved. This is rental property can't spend a lot of $.
septlewis is offline   Reply With Quote
Old 07-25-2011, 07:23 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The first thing to do is to get a "concrete guy" that knows what he is doing.
Having said that...What are you doing?
What exactly is your ultimate goal in all of this?
XXX
Old 07-26-2011, 08:20 AM   #3
old glue on concrete
I did get a concrete guy that has been doing concrete all his life & he's old. Thought he did know what he was doing and I've seen other work he's done. I just want to get the floor ready for exercise dance classes, with as little cost as possible.
Old 07-26-2011, 09:48 AM   #4
Rewards Points: 14
This is just a guess as I am far from a concrete guy but I wonder if when you used the buffer to remove the old glue you also polished the surface to the point where the adhesive won't bond? Is the concrete shiny at all? You may need to rent something to give the surface some texture for the glue to bond to. There may be a different type of glue to use that may work better also.
Snowdog is offline   Reply With Quote
The Following User Says Thank You to Snowdog For This Useful Post:
septlewis (07-28-2011)
Old 07-28-2011, 09:29 AM   #5
Trouble floor
The carbit buffer has made the concrete somewhat shinny. I may have found a product from Porter paints it's called Prep500101. Expensive but it's especially designed for removing glue residue so we will see.
Old 09-05-2011, 08:03 PM   #6
glue removal from concrete floor
My husband and I just removed old carpet and some of the glue was still tacky,anyways we did the hot water, a sander then I got my shark steamer and it worked. Did not take all layer off at once, but it broke it down enough to scrape in the thick sections and then put down some fine sand to absorb the tacky glue so it dried it out and made it much easier to then use a sander and it was gone. I also used baking soda on the tacky areato help dry and made it better to sand it away
jewelzriley is offline   Reply With Quote
The Following User Says Thank You to jewelzriley For This Useful Post:
oh'mike (09-05-2011)
Which type of glue to buy for engineered hardwood floor on concrete sub-floor in FL? noone Flooring 2 06-08-2011 09:27 AM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
Removing glue from concrete? Ike64 Tiling, ceramics, marble 1 09-26-2009 03:28 PM
