Old 10-19-2012, 01:53 PM   #1
concrete moisturee
treatment for moisture coming up thru slab ?
waynerule is offline   Reply With Quote
Old 10-19-2012, 03:00 PM   #2
Bombastic Idiot
notmrjohn's Avatar
concrete moisturee
How old is slab? Where is slab, basement, house, outdoors? Above grade, below grade? How much moisture? Where is it coming from? Why is it problem, laying new floor?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
