Concrete Lip. How To Level With The Rest Of The Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 05:06 PM   #1
Rewards Points: 12
concrete lip. how to level with the rest of the floor?
Hi, I am converting my garage to a master and am trying to level the floor for the bedroom. There's a concrete lip when I removed the wall seperating the garage from the family room. the family room is lower.
Do I use concrete leveler and pour it through out the whole room
or
vapor barrier then lay down plywood?
or?
any suggestions?
thanks
accordfreak is offline   Reply With Quote
Old 09-21-2012, 05:34 PM   #2
DIY staff
Rewards Points: 7,174
Take an over all shot----Also---
How much pitch is there in the garage?
Can you add a thicker floor without compromising the ceiling height in the family room?
What will the finished floor be?
Old 09-26-2012, 02:52 AM   #3
Rewards Points: 12
thanks for the reply.
the family room now master bedroom is full of materials so here's the best shot I can take with the high pad of concrete
the garage is no more and is now a master bath in progress.(the step up in the picture below.) The floor was built up but the master bedroom was not.
I can add a thicker floor but what would be best? the ceiling height is about 10 feet sloped down to 8.
master bedroom will be carpet.
Old 09-26-2012, 04:27 AM   #4
DIY staff
Ply wood will fail,even with a vapor barrier---it will lift and bubble with time---
Self leveling compound will work---mix with sand if allowed by the maker---it's expensive stuff----
Using deck mud works,also---if the floor needs more than 3/4"----trowel down modified thinset and pack the deck mud on top of the wet thinset.
Go to the 'tile' section and look for "Mud what is it?" by Bud Cline----excellent explanation---(top of the tile section)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
