-   -   concrete lip. how to level with the rest of the floor? (http://www.diychatroom.com/f5/concrete-lip-how-level-rest-floor-157544/)
accordfreak 09-21-2012 05:06 PM
1 Attachment(s)
Hi, I am converting my garage to a master and am trying to level the floor for the bedroom. There's a concrete lip when I removed the wall seperating the garage from the family room. the family room is lower.
Do I use concrete leveler and pour it through out the whole room
or
vapor barrier then lay down plywood?
or?
any suggestions?
thanks
oh'mike 09-21-2012 05:34 PM
Take an over all shot----Also---
How much pitch is there in the garage?
Can you add a thicker floor without compromising the ceiling height in the family room?
What will the finished floor be?
accordfreak 09-26-2012 02:52 AM
1 Attachment(s)
thanks for the reply.
the family room now master bedroom is full of materials so here's the best shot I can take with the high pad of concrete
the garage is no more and is now a master bath in progress.(the step up in the picture below.) The floor was built up but the master bedroom was not.
I can add a thicker floor but what would be best? the ceiling height is about 10 feet sloped down to 8.
master bedroom will be carpet.
oh'mike 09-26-2012 04:27 AM
Ply wood will fail,even with a vapor barrier---it will lift and bubble with time---
Self leveling compound will work---mix with sand if allowed by the maker---it's expensive stuff----
Using deck mud works,also---if the floor needs more than 3/4"----trowel down modified thinset and pack the deck mud on top of the wet thinset.
Go to the 'tile' section and look for "Mud what is it?" by Bud Cline----excellent explanation---(top of the tile section)
