Concrete Garage Floor To Living Room Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2016, 05:17 PM   #1
Rewards Points: 4
We would like to convert our garage into a living room. It has a concrete floor. Sometimes, when rain is heavy, the concrete absorbs a little water, leaving parts of the floor moist. How should we fix this? Also, any other advice about changing over garages would be welcome. Thanks
marmot87 is offline   Reply With Quote
Old 04-10-2016, 07:41 AM   #2
Rewards Points: 14,010
Re: Concrete Garage Floor To Living Room Floor
Before doing anything I'd be checking with zoning and the building dept. to see if you can get a permit to do it.
There is no coating that's going to prevent water from coming up through the slab, it needs to be addressed outside around the foundation.
A picture of the outside will be a big help, no close ups needed.
Just a few things that may be causing it:
Lack of gutters
Grade not running away from the slab.
No drain tile
Mulch or flower beds against the slab.
Very high water table
Outside walls to close to grade.
The most common way to close in that overhead door and have it not look on the outside like it was there is to cut out and remove the old apron, add a row of concrete block with rebar in some of the voids into the slab and foundation bolts making sure there not going to line up with the wall studs, pressure treated sill plate, then build the wall on top of that.
Old 04-12-2016, 04:03 PM   #3
Rewards Points: 4
Thanks for the info. I didn't get a picture of the moisture because it hasn't rained heavy in a while. It comes up in blotches at random spots in the middle of the floor. I live outside the city limits and it's pretty wild west out here, but I will make sure the permits won't be a problem. Attached are some surrounding pictures:
Concrete Garage Floor To Living Room Floor-img_3660.jpg   Concrete Garage Floor To Living Room Floor-img_3661.jpg   Concrete Garage Floor To Living Room Floor-img_3662.jpg
Tags
concrete , flooring installation , moisture , remodelling
Enlarging a room: Floor is poured concrete with different floor elevations. jedblack Building & Construction 7 09-09-2015 08:44 PM
Installing en-suite shower room onto concrete floor COACHHOUSE Plumbing 4 01-03-2012 10:34 PM
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 08:08 AM
Living room extension - concrete pad question tpagel Building & Construction 7 03-06-2009 11:57 AM
