Concrete Front Entry Refinish - Flooring - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 08:08 PM   #1
analogmusicman's Avatar
Rewards Points: 560
concrete front entry refinish
hope this is the right section of the forum!
I've got a concrete pad in front of my front door and it sure is UGLY
any ideas as to how to make it look better? maybe some sort of epoxy or a skim coat of cement? I've tried indoor/outdoor carpet (which is on there now...UGLY!) and will be blasting that stuff away with a power-washer.(bought it at HD...their carpet isn't too good ,at least their I/O...bought some high quality indoor/out about 15 years ago and it's still going strong in back of the house)
tnx,
analogmusicman is offline   Reply With Quote
Old 07-30-2009, 11:54 PM   #2
Rewards Points: 4,528
there're several products avail to you but NOT at any apron store EVEN IF THE BAG SAYS RESURFACING elitecrete & concrete network are 2 sources.
we don't use epoxies for external use,,, you'll also need an angle grinder & diamond turbo cup wheel
stadry is online now   Reply With Quote
Old 08-02-2009, 06:53 PM   #3
Rewards Points: 560
here's some pix. see how UGLY it is? how about some sort of tile?
tnx,
concrete front entry refinish-slab.jpg   concrete front entry refinish-slab1.jpg   concrete front entry refinish-slab3.jpg
Old 08-02-2009, 06:58 PM   #4
Was there ever a post in the outside corner?
Seems like there was with a downspout?
Old 08-02-2009, 07:00 PM   #5
piece of cake these were worse,,, installing tile's not a good idea as wtr'll eventually enter the grout, freeze, & pop off the tiles,,, back where you started, eh ? ? ? bear in mind we do this for a living BUT you could come close
concrete front entry refinish-green-tile-brick-border.jpg   concrete front entry refinish-tape-ashlar.jpg
Old 08-02-2009, 09:22 PM   #6
Rewards Points: 560
yeah Scube, there WAS a post there (all rotted etc) which will be replaced before the tile goes on.
tnx,
Old 08-03-2009, 08:27 PM   #7
Rewards Points: 560
welll,tile is out! my wife got spooked by the tiles popping out because water seeped in and froze.
going to have to be either the entire slab replaced or re-surfacing.
tnx,
Old 08-03-2009, 09:15 PM   #8
it happens even down here in ga btw, resurfacing's much less than new
Old 08-03-2009, 11:09 PM   #9
Rewards Points: 560
do you think resurfacing is ok? is there a possibility that water will somehow get under the new surface and freeze? THAT could be a mess!
tnx,
Old 08-05-2009, 07:37 AM   #10
of course i do,,, those post'd pics were of jobs that were worse than yours,,, all have been down over 5yrs in freeze-thaw climes,,, properly installed, there's no chance of wtr infiltration as the o'lay mtl bonds molucularly to the properly prepp'd original conc surface,,, here's another.
Old 08-05-2009, 08:18 PM   #11
Rewards Points: 560
well, I got an estimate for "capping" the slab with 2.5 in. of concrete and it's a whole lot more desirable than getting the slab replaced. (less costly) the guy that gave me the estimate says the existing slab is in good shape so pulling it out would be "overkill". my wife isn't all that interested in resurfacing with some sort of design since all the other houses around have a plain concrete slab in front of the front door. more estimates on the way!
tnx,
Old 08-05-2009, 09:36 PM   #12
They can also stamp a pattern into the concrete
And or add color
Might want to see how much that adds
Old 08-05-2009, 11:06 PM   #13
Rewards Points: 324
There is a guy on a couple of the Holmes on Homes episodes that does this kind of work. It turns out looking beautiful.
What kind of company do you call to find out about having cement steps finished like that?
There is a company in Canada that sells products in the U.S. for this kind of work. I called them and they sent me a DVD giving exact directions on how to use their coatings. I haven't watched it yet. Here is a link to their website:
http://www.daichcoatings.com/
gma2rjc is offline   Reply With Quote
Old 08-05-2009, 11:10 PM   #14
Rewards Points: 560
well, Scuba,that's nice,I mean REAL nice. my wife agrees too!
the only question is, can we get it done at a reasonable cost. I don't think the guy who came today could do it. probably end up with a plain slab.
tnx,
Old 08-06-2009, 06:07 AM   #15
2 1/2" cap's really much more'n necessary but could be accomplished by either a bond'd OR unbond'd overlay ( cap ),,, none of the pics i post'd were thicker than 1/8",,, even installing a thin-stamp'd overlay's only 3/8" max,,, to my knowledge, daich is a reseller, not a manufacturer,,, google ' elitecrete ' for the largest manufactureing & dedicated distribution network - even in canada.
if you saw the diy tv segment on the back porch/patio o'lay, it was rod johnson & elitecrete along w/the show's 2 reg hosts.
if
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Front Entry Door Paint/Color Advice gibear2k5 Interior Decorating 23 08-30-2010 05:52 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 10:11 AM
Concrete Block under the Front Door Robinjail Building & Construction 1 06-27-2006 11:04 PM
