Old 08-21-2011, 03:58 AM   #1
Question
Concrete Flooring – questions
I really have my heart set on polished concrete floors and wanted to know more about them before I go get bids.
I know this is a Do it Yourself forum but I do know that contractors come on here and I would really like an unbiased opinion. I know in my heart I do not hold the ability to do such a complicated process.
Anyway here are my questions:
  • What is the benefits of Polished vs Epoxy? (in terms of over all life of the floor)
  • Is it possible to polish the underlying concrete that is already in a house if it is in good condition and not in need of repair? or is it manditory to lay new concrete?
Grofica82 is offline   Reply With Quote
Old 08-21-2011, 09:56 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
you can polish your existing concrete. the concrete will need a protective coating. the problem with epoxy coatings is that they will amber and chalk over time. i would use a polyurethane that is designed for concrete. http://surecretedesignproducts.thoma...ncrete-sealers
mustangmike3789 is offline   Reply With Quote
Old 08-21-2011, 10:18 AM   #3
Does that have the same really high gloss finish?
How long does an epoxy floor usually last...
I am still unsure which version of concrete I really like but i want really strong colors...
Something like this is what i am trying to shoot for...
Old 08-21-2011, 08:21 PM   #4
That looks like epoxy.POLISHING in side a home might not be cost effective.A lot of grinding and polishing.You wont be living there while it's being done.About 6.00 sq. ft.dye/wax/sealer.Up to 2000 grit. All Home Depot stores are dyed, polished floors .Good Luck, Ken.
We all no alot but can only do a little------.
kchunt is offline   Reply With Quote
Old 08-21-2011, 08:43 PM   #5
A polished concrete floor will last 2 lifetimes plus 5 days.Epoxy floors do need a little work now an then.Look for an Elite crete installer in your area.The epoxy floors are next to none when it comes to looks.The REFLECTOR floors are perfect inside homes.Go to elitecrete.com. good luck,Ken.
We all no alot but can only do a little-------.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
A couple of noob concrete finishing questions SMRcalidiv Building & Construction 11 07-31-2011 08:27 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
few questions on wood flooring Mr. Michael Flooring 1 05-19-2011 03:01 PM
Stained Concrete Flooring Questions voodoo73 Flooring 5 11-17-2009 09:24 PM
