Concrete Floor Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 05:54 AM   #1
Question
I have a concrete floor which has a number of holes ranging from small to larger (3-4cm).
Can I simply mix up some concrete and fill it in? I'm going to be putting an underlay and carpet down on top.
Thanks for any advice.
splitplixel is offline   Reply With Quote
Old 04-08-2012, 08:39 AM   #2
DIY staff
Rewards Points: 7,174
Use a vinyl patching cement or Feather Finish----regular concrete is to corse to use for patching--
PaliBob (04-10-2012)
Old 04-08-2012, 08:55 AM   #3
Thanks for the quick response.
Would it matter if I'm just using it to fill when an underlay and then a carpet it being put over it?
Could you recommend a product?
Old 04-08-2012, 09:03 AM   #4
DIY staff
Go to the flooring section and look for 'Feather Finish' --by Ardex---that is a nice one,although a bit pricey--
Any vinyl concrete patch should work for filling small holes under carpet---so the choice is yours.
Feather Finish is available at the Home Depot---and most tile stores.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
PaliBob (04-10-2012), splitplixel (04-08-2012)
Old 04-08-2012, 09:07 AM   #5
Thanks.
The Following User Says Thank You to splitplixel For This Useful Post:
oh'mike (04-08-2012)
Old 04-10-2012, 02:34 AM   #6
Location: Crusader House 2nd Floor 145 157 St Johns Street London UK
Smile
First, Chip the surface of the concrete to remove any high material, and to create a rough surface for the repair cement mixture to bond to. For small jobs, a chipping hammer will be all you need, but larger repairs are much easier with an electric chipping hammer or even a jack hammer.
Then, Clean the dust and debris from the area you have chipped. This will allow the new material to have a solid surface to adhere to. After that,mix the cement/sand material you will use to fill in the area you have chipped out.
Add a latex or polymerized liquid bonding agent to the dry sand/cement mixture, using enough to thoroughly wet the material and bring it to a stiff, plastic consistency. Note that some bonding agents are applied directly to the area to be patched, like glue, so follow the instructions on the manufacturer's label.
I think this will help you
Thanx
fangeos2 is offline   Reply With Quote
The Following User Says Thank You to fangeos2 For This Useful Post:
splitplixel (04-10-2012)
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
