Concrete Floor...the Pits! - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-17-2008, 06:29 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I am curious for my future reference, What can you use over concrete as a underlayment? I've never put anything other than carpet or VCT down in a basement and never used an underlayment. But if I was installing a floor that required a sub floor, what would I use if I could not use Lauan?
Say what!!!!!!!
Old 09-17-2008, 09:50 PM   #17
analogmusicman's Avatar
Rewards Points: 560
ok, so I'll forget the "muriatic acid"! I cleaned it by hand. big machines do create dust etc. and that won't do since I just painted the walls. (shoulda waited,huh) now to fill the pits...
tnx,
analogmusicman is offline   Reply With Quote
Old 09-20-2008, 01:38 PM   #18
Rewards Points: 560
so I cleaned the floor (by hand,very labor intensive!) and patched those "pits" with Planipatch and "durn it", that stuff is like "mud" (you know,wall compound") when you patch a nail hole. it looks fine when it's wet,nice and smooth,but when it's dry it shrinks leaving a nice "dimple". I sanded and went over it again,trying for a smooth patch, but when it was dry, dimples again! what do you do,keep going over it until it's perfectly smooth? don't you want a perfectly smooth surface for the tiles? will the primer fill those dimples? hey Nestor!
tnx,
Old 09-21-2008, 03:02 PM   #19
Question
While you are on that subject of subfloors, I was wondering if you could
use hardibacker set in thinset over a concrete floor or wonder board.
I need to bring a concrete up to the terrazzo level for wood flooring
to be glued down
therugdummy is offline   Reply With Quote
Old 09-21-2008, 03:12 PM   #20
Registered User
Termite's Avatar
to be glued down
You need to post your question in a new thread. That way people will see it and you'll get the answers you need.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
