-   -   Concrete floor in bathroom (http://www.diychatroom.com/f5/concrete-floor-bathroom-10822/)
markm50 08-18-2007 11:27 AM
Recessed concrete floor in bathroom
2 Attachment(s)
We are in the middle of a major bathroom remodel and looking for help with the Shower. We need to build a custom pan where the old shower and tub were but the concrete and drains are challenging us.
1. The old shower floor pan is on a recessed part of the slab about 2" below floor level. We would like to bring the entire floor to one level sloping to the drain. Should we build it up to floor level or cut out the existing floor area and re-pour the slab?
2. We are not sure whether to use the second tub drain it the new shower pan or just cap it off. It is only about 34" away from the shower drain.
Hopefully these pictures will help explain our predicament.
JazMan 08-18-2007 01:04 PM
Hi Mark,
You didn't say what the size of the new shower will be. The shower drain should be installed as close to center as possible. Also the drain needs to be 2" pipe, the tub drain assembly is probably 1 1/2"?
Start with that info.
Jaz
markm50 08-18-2007 02:01 PM
Originally Posted by JazMan (Post 58318)
Hi Mark,
Jaz
Jazzman,
Current shower size is 36X36 with a 2" drain close to but not directly on center. The new shower width will be 48" wide with an walk-in opening at the left, (handicap accessible). I am thinking I need to saw the slab to the size new with of 48" and probably 60" deep to make a new pan for the new wet area. If I do that I might as well have a plumber rough the drain in
the center of the new floor.
Mark
JazMan 08-18-2007 04:15 PM
I think you're right? That floor and drain needs to be removed and reconfigured. As for the shower its self, you should consider using the Schluter kerdi Drain system, it's the only way to go I think. http://www.schluter.com/143.aspx
Jaz
