-   -   Concrete chip repair prior to ceramic floor tile? (http://www.diychatroom.com/f5/concrete-chip-repair-prior-ceramic-floor-tile-46367/)
libbybuddy 06-10-2009 04:46 PM
I would like to put ceramic or porcelein tile on my concrete family room floor (lowest level in a tri-level). I've removed the carpet and tile and about 90% of the mastic. The concrete on the periphery of the room is chipped. How do I repair the concrete? The inner portion of the floor is intact and crack free so I just need to repair the chips around the edges.
Bob Mariani 06-10-2009 05:05 PM
you can just fill these cracks with the same thinset used for setting the tile. If they are deeper than 1/2" fill first and let dry, otherwise just left the thinset fill them in as you tile.
libbybuddy 06-10-2009 05:54 PM
Thanks for the info. They are deeper so I'll have to do a two two step process.
