Folks,
To make a long story short...we moved into a house in which we had to remove all the old carpeting and old tile underneath it...which left us walking on the concrete slab. We ended up painting the slab with concrete paint until we had the funds to replace all the flooring. Anyway we want to install bamboo Laminate (no glue flooring) in 3 of the rooms....I understand the concrete slab should be real close to level...so down to the home improvement store to obtain the necessary items...when bam...it hit me...it would appear that I must remove the paint from the concrete slab in order to use the Self Leveling Compound because it must adhere to the slab....I really do not wnat to remove it.....its a job I would not look forward to doing. Is there something I can use to level the areas of my concrete slab without having to remove the paint? Initially I was thinking I could use Red Guard on top of this paint which would be taky upon drying that would allow the Self Leveling Compound to adhere to it.....not sure that the right way to go.
Any suggestions?
SJC
Any suggestions?
SJC
