Computer In My Unfinished Basement & My Feet Freeze When Sitting At My Computer - Flooring - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 06:53 PM   #1
Computer in my unfinished basement & my feet freeze when sitting at my computer
I live in Maine. My computer & desk is in my basement. It is pretty warm with my FHW boiler, but ...... my feet freeze due to the concrete floor. I've tried putting carpet under my desk but that does not help. What can I put down under my desk (nothing permanent) so my feet stay warm? It has to be fairly cost effective because I canot afford to spend tons of money. any suggestions? cork? those thick rubber mats that are used to stand on like @ supply/warehouses for people that stand all day?
nroy is offline   Reply With Quote
Old 12-18-2011, 07:47 PM   #2
Rewards Points: 346
Anything that won't transfer cold would be a good start.
I have seen LOTS of offices where people put a small space heater by their feet.
dougp23 is offline   Reply With Quote
Old 12-18-2011, 08:05 PM   #3
A Little Of Everything
Rewards Points: 1,364
Wear slippers. Seriously.
If that's not enough, get a heated mat. Anything beyond that is going to get very spendy, without a cost effective return.
http://cozywinters.com/shop/tfw.html
DrHicks is offline   Reply With Quote
Old 12-18-2011, 09:36 PM   #4
I live in Maine ....... I don't go without slippers or shoes in my basement. And, I do use a portable heater sometimes when it is real cold outside but honestly, my boiler keeps the basement very warm.
But, I did not know about the electric foot warmer pads thank you!!!! I will definately be buying one.
THANK YOU!!!!
Old 12-19-2011, 02:44 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Years ago I had a similar problem. I built a wooden box and put it under my desk to put my feet on. It was probably 18" wide, 12" deep, and just tall enough to keep my feet off of the cold concrete, slanted for comfort.
Old 12-19-2011, 03:41 PM   #6
Might try placing a small light fixture under your desk (on the floor)
Marvel is offline   Reply With Quote
Old 12-20-2011, 08:33 PM   #7
Rewards Points: 1,448
Concrete has a very low R value (insulating quality) and the ground underneath probably has a temperature of 50 degrees give or take.
The wood platform or carpeting or whatever you put down has to have some insulating qualities so your feet don't keep getting cold.
Old 12-20-2011, 10:15 PM   #8
Old School
Willie T's Avatar
Move the computer upstairs. Your family probably misses you anyway.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
AGWhitehouse (12-21-2011)
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Patching unfinished basement ceiling? Pictures included stefonroman Building & Construction 2 03-02-2009 01:31 PM
unfinished basement brackh Electrical 17 02-14-2008 04:20 PM
Wiring Unfinished Basement Renovator Electrical 12 04-25-2006 10:36 AM
