Is Commercial Carpet Good For DIY? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2009, 08:31 AM   #1
Question
Is laying commercial carpet, like the gray colored one at Home Depot a suitable DIY job?
I haven't laid any carpet before. I've put down linoleum successfully.
The plan is to not use a pad.
Do the moldings have to be removed and replaced or is the carpet cut up to the existing moldings?
Any other things to do or watch out for?
TomBrooklyn is offline   Reply With Quote
Old 08-04-2009, 11:47 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Are you planning to: glue it down, or loose lay?
Old 08-04-2009, 12:10 PM   #3
Hi,
There was a commercial carpet there before that I just ripped up and it was just tacked down around the perimeter right from the top. I never noticed the tacks before I pulled it up so that seemed to work OK. I could glue it if that's a good way to go. I don't know if loose lay is a good idea.
Old 08-04-2009, 02:38 PM   #4
Floorwizard's Avatar
glue down would be the easiest using less tools.
but seams can still be rough....but still easier.
Floorwizard is offline   Reply With Quote
Old 08-04-2009, 03:25 PM   #5
Rewards Points: 82
Loose-lay will wrinkle.
Tags
commercial carpet
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 04:41 PM
Carpet Underpad jerryman Flooring 11 02-14-2009 09:03 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 08:49 PM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 04:21 PM
