Cold Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 12:23 PM   #1
Cold Floors
My condo was built in 1973 and sits on concrete. The floors are always cold even though it has carpeting. I want to get some heat on the floor (not radiant heating) and I need suggestions as to what I should use on the floors to warm it up. Because I am on the bottom, wood flooring/laminate is not recommended by the Association.
Any suggestions?
viejaloca1954 is offline   Reply With Quote
Old 01-07-2012, 12:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Wood flooring/laminate is colder than carpet anyway.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-09-2012, 05:13 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Pardon my confusion but, a little clarification please... you want to warm the floor but you don't want to accomplish this by warming the floor??
In case I'm missing something, look up Zmesh on the net. It installs directly under your carpet. You'll want to lay a 1/8 or 1/4 plywood over the top to protect it from the carpet removal later though so you will add...5/16" max if you use 1/4" leuon to the floor.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 05:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
