COLD Concrete FLOOR...help - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 03:22 PM   #1
COLD concrete FLOOR...help
Hello all...big delemma here...i have a family room that is build over my garage and the floor is a concrete slab..the walls and ceiling are insulated well and there are two heat vents that were added as an extention from the house furnace..however..the floor is cold..there is padding and thin carpet there now, but the floor is still cold....
do i get better thicker carpet and padding? Do i get radiant floor heat for under the carpet? do i insulate under neath...please help..
Me
mikebmore is offline   Reply With Quote
Old 11-18-2008, 03:29 PM   #2
Floorwizard's Avatar
there is heat pads you can install and get hooked up by an electrician.
Products like: NUHEAT and such work great.
Or a nice WOOL padding for under the carpet would probably be more affordable.
Floorwizard is offline   Reply With Quote
Cold concrete floor..HELP!! mikebmore Tiling, ceramics, marble 8 06-05-2011 09:04 AM
cold concrete floor RuthP Flooring 4 02-03-2008 11:13 PM
Cold Weather Concrete in Post Hole OK?? Jerrycast Building & Construction 6 01-25-2008 10:47 AM
how cold is too cold for concrete flatwork THEBIGPUNN Building & Construction 2 12-24-2005 03:55 AM
