Closing Up Floor Register - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By HotCoffee
Old 01-10-2017, 10:05 PM   #1
Rewards Points: 174
Closing up floor register
Redoing one of our rooms; looking for advice on how best to close up this floor vent/register WITHOUT taking up the hardwood that surrounds three sides of it.
Thoughts? Mine was to simply get a piece of sheet metal bend/form it into the opening, put some underlayment or other stiff board and be done with it... open to other suggestions.
tb582 is offline   Reply With Quote
Old 01-11-2017, 06:38 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
Re: Closing up floor register
Accessible from the underside or no? Are you pulling out the old duct line?
Old 01-11-2017, 07:25 AM   #3
Rewards Points: 174
Unfortunately not accessible from the underside. - no, also not pulling the line out but by closing it up the airflow will be redirected to one of the other offshoots.
Old 01-11-2017, 01:41 PM   #4
Artist
Rewards Points: 30
My method to get rid of one was to nail a... cleat, or sill, whatever you want to name it around all 4 sides of the hole at the depth of the thickness of whatever I cut to fit the hole, and dropped in. Then its flush and no fiddling around. Also- wrongly or rightly, we stuffed the duct with a fair bit of insulation to stop whistles.
ZZZZZ and Flyas like this.
HotCoffee is offline   Reply With Quote
Old 01-11-2017, 10:01 PM   #5
firehawkmph's Avatar
Rewards Points: 1,792
I would take up those small pieces of flooring next to the hole and then use an oscillating tool to cut off that skinny piece on the other side. Then cut a piece of plywood the same thickness and screw it down. Take about ten minutes to do that.
Mike Hawkins.
firehawkmph is offline   Reply With Quote
Old 01-11-2017, 10:22 PM   #6
ZZZZZ's Avatar
Rewards Points: 564
I closed up and moved a floor register recently, though I had good access from underneath. It was pretty easy
Without access from underneath, I would treat it like a drywall patch: insert and attach a couple of wide strips of scrap 1x4 or whatever to act as a backer and then glue and screw a piece of sub-floor to the backers, the same thickness as the rest of the floor.
I think this is what Mr. Coffee is suggesting, too.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Cannot upgrade 3/8ths inset hinges to self closing? PaulPool89 Carpentry 2 10-20-2015 10:36 AM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 09:03 PM
Garage door problem - not closing completely francis Electrical 4 07-08-2010 01:27 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 02:39 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
