Click-lock Engineered Wood - Flooring - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 11:28 AM   #1
click-lock engineered wood
I just installed your click lock and it creeeks . What can be done about it ?
Abe Qutub is offline   Reply With Quote
Old 07-28-2010, 11:31 AM   #2
Click -lock engineered wood floor
I have just installed clicl lock engineerd floor and it creeks badly . How can I fix it ?
Old 07-31-2010, 08:40 AM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
did you use the foam underneath it?
Millertyme is offline   Reply With Quote
Old 07-31-2010, 10:18 AM   #4
Engineered wood flooring issue
I did use the premium underlayment "airguard" !
Old 08-01-2010, 09:29 AM   #5
Handyman
Rewards Points: 512
what did you lay the floor over?
canadaclub is offline   Reply With Quote
Old 08-01-2010, 03:33 PM   #6
3/8 plywood over particle board sub frame....floor was solid,no creeking or flexing untile the click lock was installed. So it got to be either the click lock engineered material or the installation ? If the base board is siting tight against the click lock would that cause the creeking ?
Old 08-01-2010, 03:49 PM   #7
Rewards Points: 5,336
If the subfloor wasn't level enough the floor will be bridging the low spots until someone steps on it. In the instructions, it states what the parameters are for a level floor.
Ron
Advice on engineered wood for new townhome sportinwla Flooring 11 12-16-2009 05:00 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 10:13 AM
adjoining rooms getting out of square on engineered wood installation jencastro Flooring 5 09-22-2008 09:58 AM
TrafficMaster Engineered Wood Flooring in Basement Vermonster Flooring 4 04-02-2008 11:23 AM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
