Clearance Issue - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 09:18 AM   #1
clearance issue
I am installing tile in my laundry room and after doing a dry fit of backer board and tile on our plywood I noticed that my back door would not open and no I'm stuck and don't know what to do.
ladyms is offline   Reply With Quote
Old 02-17-2012, 09:51 AM   #2
Rewards Points: 528
You will need to cut the door to get it to work, or you need to use ditra or similar to back the tile.
framer52 is offline   Reply With Quote
Old 02-17-2012, 11:03 AM   #3
The door is steel and I've read It wouldnt be the best thing to do. My husband said the 1/2 backer board alone would prevent the door from opening,so if my calculations is correct the Ditra 1/8 thick and my tile 3/8 is 1/2" so that would not work for me either. Is it ok to cut the door?
Old 02-19-2012, 11:30 AM   #4
You will need to remove the trim then remove the whole jamb. When done with that see if there is enough room left in the R.O. to raise the jamb. If there is then install the proper size board under the threshold and reinstall jamb. If not you can raise the header and then shim and install door. A lot of work but imo thats how to do it. Hope this helps.
kj6887 is offline   Reply With Quote
Old 02-19-2012, 12:58 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
Did you remove any 1/4" plywood that is over the subfloor? This would be what your old vinyl was installed to. Can you confirm that the plywood you see is the subfloor and not an underlayment? You are also using the wrong concrete backer. 1/2" is for walls, use 1/4" or better yet, Ditra.
You might want to raise the door anyway, cuz it might be nice to have clearance for a rug too.
Jaz
Old 02-19-2012, 07:37 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
Jaz, will 1/4" backer be too flimsy for walking tile if they end up doing that?
Sent from my iPhone 4 ios5
JetSwet is offline   Reply With Quote
Old 02-19-2012, 08:23 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Absolutely not. 1/4" is for floors and counters. The backer board adds virtually no structural strength to the subfloor system. All it does is give you a "tile-friendly" surface for tile.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
JetSwet (02-19-2012)
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 09:53 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Tile subfloor - clearance issue Scoutsout Flooring 27 03-10-2011 09:36 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
