Cleaning Travertine Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 09:50 PM   #1
Cleaning travertine floors
Will using a steammop on a sealed Travertine floor harm the sealent?
millelacs is offline   Reply With Quote
Old 06-18-2010, 08:54 AM   #2
Hi Millelacs,
Can't really answer your question except to say exercise caution. Natural stone should be cleaned using the appropriate cleaners as they are susceptible to staining. I once had a customer use vinegar to clean a marble floor and the result was not a good one. Be weary of what you read online for this type of product.
I would strongly suggest you visit a specialty floor covering/tile store and see what they have available and have this discussion with a local expert.
rcuerrier is offline   Reply With Quote
Old 06-19-2010, 08:01 AM   #3
A steamer would work quite well as most people use to much water when mopping their stone floors. First remove the grit with a soft broom or vacuum, then use the steamer. Do not put any harsh cleaners in with it. If need be use a neutral pH stone cleaner.
www.heavensentfloorcare.com
travertine guy is offline   Reply With Quote
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Just bought a house with Travertine floors. Can the marble be refinished? Cost? Waterfowler Flooring 17 09-22-2009 02:00 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
travertine floors Keith Carlson Ceramic Flooring 4 09-29-2008 11:41 PM
Any cleaning solutions for getting paint off of floors? 57michele Painting 4 09-20-2006 12:19 AM
