-   -   Cleaning Old Hardwood Floor (http://www.diychatroom.com/f5/cleaning-old-hardwood-floor-85156/)
chisels1 10-28-2010 08:33 PM
This is part 2 of my Dining Room Redo. Part 1 was in the Painting Forum.
We ripped up the Rug, what we have is nice Hardwood 1928 vintage ( Maple? ) anyway the pattern is like a frame around the edge of the room about 2.5 feet then its straight pieces running the short length of our 13' x 16' room.
We don't plan on Sanding until Spring but I'd like to clean and bring out the color without a wax or ruining the eventual Sanding job.
I'm not sure what the finish is now so what could I do without harming anything.
Interesting there are a couple of holes where Radiators were, about a 2" hole
tacomahardwood. 10-30-2010 05:06 PM
First go get a lead test kit and use it , I have found lead in pre 1964 shellac . a completely wrung out towel and some dish soap , If you are going to refinish .You don't want wax impurities to contaminate the future finish . Or a little paint thinner , But use this moderatly and keep and eye on whats rubbung off .If it is wax then you may scub the wax finish off .
I could already be a wax finish , In that case lacquer will rub some off fairly quickly . tacomahardwoodfloors.com
ianc435 11-11-2010 08:54 PM
Is cleanig wood floors newly finished with vinegar and water the best?
