Cleaning Hardwood Floors After Ripping Out Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 12:06 PM   #1
Cleaning Hardwood Floors after Ripping Out Carpet
Hello,
We recently purchased an old home that installed carpet over some hardwood floors in the living room. We removed the carpet, staples, and tack strips so far.
Is there an easy/good way to treat the small holes left by the staples and tack strips?
What is usually done to clean/treat the wood after doing something like removing the carpet? We currently have no furniture in the house, so we want to do all of the messy cleaning while we can do it easily.
Thank you for your help/advice!
Cheers,
B
banzzy is offline   Reply With Quote
Old 12-04-2013, 10:19 PM   #2
Rewards Points: 920
You probably want to vacuum very well, then get someone in to screen the floor and put on a coat or two of finish.
You could also rent one of those diy floor sanders which have 3 spinning heads. This simply allows you to rough up the floor a bit, then you can put on a coat of finish. You rough up a bit between coats as well. I would think 2 coats would fill all the small holes left by staples.
cleveman is offline   Reply With Quote
Old 12-05-2013, 05:37 PM   #3
Rewards Points: 3,352
If your going to leave the flooring exposed,i'd have the pros do it,especially if you've never done this type of work before.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
joecaption (12-05-2013)
Old 02-14-2014, 09:16 PM   #4
Mr
You are going to need to get your floor re-finished. I wouldn't repaint the floor, you would never be able to fix that..
MikoMcGreg is offline   Reply With Quote
Tags
cleaning floors , hardwood floor finish , hardwood floor repair , removing carpet
Creaky floors under carpet konradsa Flooring 8 01-23-2012 11:29 PM
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 04:19 PM
should i remove hardwood floor or carpet over? Please help deathbymeeting Flooring 3 07-28-2010 06:07 PM
Tile, hardwood, and carpet questions ws450r Flooring 1 07-02-2010 02:40 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
