Cleaning Grout Off Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 04-06-2007, 05:54 PM   #1
cleaning grout off tiles
Hi I just recently moved into a house. The bathroom tiled wall there is a thin coat of grout left on the tile. Any suggestions on how to remove the grout off the tile?
Thanks in advance for any ideas.
seaox67 is offline   Reply With Quote
Old 04-06-2007, 06:01 PM   #2
Home Improvement Guy
ron schenker's Avatar
Is it actually grout or a haze left from the grouting? If it's haze, just buff it off with a dry clean terry cloth. If it's grout (which it shouldn't be) try to chip off the big stuff then wipe with a damp soft terry cloth.
ron schenker is offline   Reply With Quote
Old 04-07-2007, 09:19 AM   #3
Many Thanks for your reply Ron.
I have tried that also a razor blade brillo pads and good old elbow grease... Not sure else to do? Is there a chemical of some sort?
In places it is a slight film, like the guy who did it didnt wipe all the grout off the tiles when he was meant to.
Old 04-07-2007, 12:15 PM   #4
Tile and Paint contractor
if you go to a good tile shop you can get "grout release"
use liberally
unless the problem is a crap job on sealing the tile
what kind of tile is it?
matter of fact, post a picture please
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 04-07-2007, 01:12 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
Hey Matt,
Don't you think it's a little too late for a grout release? Plus as described, it sounds like it's a glazed wall tile, not natural stone like slate, so you would never use grout release in the first place.
Try this. Wipe with 50/50 white vinegar/water. If this doesn't work good enough, try vinegar full strength. If that doesn't do it, get a grout film remover. Last resort, sulfamic acid crystals per directions. A real tile shop will have the last 2 products.
Jaz.......LABICER booth #2932 Coverings '07
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
Grout and tiles... Leikela Flooring 11 06-18-2007 02:59 PM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 02:20 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
