Cleaning Floor After Carpet Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 09-09-2013, 01:50 PM   #1
Rewards Points: 111
cleaning floor after carpet removal
I just pulled up a carpet for the first time, wasn't sure what to expect. Well, the floor is a pretty clean chipboard subfloor. But there is some kind of thin paper all over the floor, not uniformly, but in large patches. It is papery on the down side and like a thin layer of foam rubber on the up side. It peels off easily enough, but given the size of the room, it could take a lot of hours to remove. Is there a tool for removing this stuff? I'm thinking about something like a wallpaper removal brush. The floor was nice and dry, so I'd prefer not to use a liquid solution. Any suggestions?
Thanks.
wengang1 is offline   Reply With Quote
Old 09-09-2013, 04:28 PM   #2
DIY staff
Rewards Points: 7,174
If it's stuck--a long handled steel scraper is the usual tool---available in the flooring department of most stores----
Old 02-26-2014, 05:25 AM   #3
Mr
It looks like you're not covered for an insurance claim for wear and tear. However, if any sudden and accidental damage occurred to the flooring while you were removing your carpeting, you would be able to put a claim in. If this happened, get a public adjuster...
MikoMcGreg is offline   Reply With Quote
Old 02-26-2014, 05:50 AM   #4
Rewards Points: 14,014
http://www.amazon.com/Bully-Tools-92.../dp/B000PAQEKU
Old 02-26-2014, 06:33 AM   #5
Rewards Points: 111
yeah, I did end up buying that long handle steel scraper. It worked pretty well. One problem with it is as I was using it, the nuts kept loosening off the bolts. Also, I went back over the floor with the gum scraper and a razor blade to get the lower-profile staples, nails, bumps, etc. before I put the floor down. Thanks for the answers all.
The Following User Says Thank You to wengang1 For This Useful Post:
oh'mike (02-26-2014)
Old 02-26-2014, 10:16 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
What???????????
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Pulled up carpet seam in doorway, now there is a gap... how to fix? thisisjason Flooring 3 11-19-2012 02:29 PM
carpet to laminate transition 8roty Flooring 3 11-08-2010 06:41 AM
Cleaning Walls after wallpaper removal saggdevil Painting 28 06-16-2009 04:32 AM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Cleaning Pet Stains From Carpet KHooper General DIY Discussions 3 02-23-2005 06:52 PM
