Old 07-30-2006, 06:25 PM   #1
Cleaning ceramic tile surfaces
Hi guys, I'm hoping someone here can help...
I've recently bought a house which was previously owned by a guy who obviously loved DIY, but might not have been quite as good at it as he thought
The bathroom has been tiled from floor to ceiling - some of the grout is needing replaced (which is easy enough) - but the tiles are needing cleaned.
Specifically - it looks like when the guy was removing the excess grout during fitting - he didn't clean the sponge or tile surface properly, and the tiles have a kind of white sandy texture on their surface - it makes them very difficult to clean properly (and almost impossible to shine)
Is there an easy way to remove the thin film of grout from the tile surface, so that I can then clean and buff the tile surface? A chemical or something perhaps that can make it easier to remove?
Thanks for your help.
Dave
hexland is offline   Reply With Quote
Old 07-30-2006, 07:41 PM   #2
Try vinegar and water 50/50, no good.
Then straight Vinegar, still no good.
Try Sulfamic acid crystals, HD has them.
Oh, and use a good scrubby pad, HD has them with the handle, they come in a package with different colors, each color is courser than the next.
R&D Tile is offline   Reply With Quote
Old 07-31-2006, 11:24 AM   #3
Floorwizard's Avatar
good advice
Floorwizard is offline   Reply With Quote
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
