Cleaning Adhesive From A Concrete Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 10:00 PM   #1
Cleaning adhesive from a concrete subfloor
My house had vinyl tiles throughtout which I've taken out, but have this black adhesive that is still on the subfloor. Any way to clean the concrete well enough to stain with a Kemiko-type product? Should I even attempt it? Thanks.
sparinaa is offline   Reply With Quote
Old 09-15-2007, 10:16 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Forget it! The only way to get down to clean concrete is to use a terrazzo grinder and sand while flooding the floor with water.
You could use carpeting or ceramic tiles.
Jaz
Old 09-15-2007, 10:21 PM   #3
Appreciate the quick and honest reply.
I guess tile or vinyl (again) is the way to go in the bathroms. Any thoughts on vinyl versus laminate in the other areas?
Old 09-07-2011, 12:11 AM   #4
I was searching for some info regarding the subject of this post. I know it is from 2007 but hopefully it will help out others. I did not find much information on removing the adhesive on google so I decided to try Goo Be Gone and it worked............
ajaxaudish is offline   Reply With Quote
Fastening Subfloor Plywood To Concrete Slab Hages Flooring 9 01-15-2009 11:07 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Adhesive removal from concrete sod Flooring 3 04-02-2007 08:41 PM
Rotted Subfloor under concrete amy Flooring 1 10-27-2005 09:36 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
