Clean Floor After Vinyle Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 06:58 PM   #1
Clean floor after vinyle removal
After you carefully remove the vinyle tile and the adhesive with asbestos in it.What if you do get some dust on the floor. How do you properly clean that up without making a bigger problem? Even if you use water isn't there dust on the floor after the water dries.
Mnowak24 is offline   Reply With Quote
Old 01-13-2012, 07:00 PM   #2
Rewards Points: 13,740
When you clean off the glue the saw dust will come off with it.
What do you plan on installing over the subfloor?
how to clean payne gas sensor? dapperdraker Appliances 3 06-26-2011 12:28 PM
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 11:36 AM
How often do you clean your Paslodes Bearcreek Tools 1 08-24-2009 09:00 AM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
