Old 09-15-2009, 07:08 PM   #1
Question Choosing a Floor Refinisher
My husband and I have no clue about how to choose someone to refinish our Bruce (engineered?) hardwood floors. Could someone jump in with a list of the questions we should be asking a potential refinisher. Or, just let us know what steps are involved so we can see if the man is going through the same process as you would go through (e.g, isn't there some sandpaper sequence? how many coats? etc.)
Also would like to know if anyone has an opinion on which is the better waterborne product: MinWax or a product made by Bona called Mega? Oh, should mention that in addition to sanding and applying the poly, we will need to have the floors stained in order to match the exisiting stained stairs.
Thanks so very much for any information.
polly1947 is offline   Reply With Quote
Old 09-23-2009, 12:01 AM   #2
As it may be too late, The first thing i would ask is if the person has ALOT of experience staining wood floors. The sanding process is much more intricate and most people i've seen don't know how to sand that way. The darker the stain, the more difficult to apply evenly. Ask him questions about the process. Other than that, i would recommend doing research on the process yourself so as to have a general idea.
TheFloorGuy is offline   Reply With Quote
Old 09-23-2009, 06:06 PM   #3
Default Choosing floor refinisher
Thanks for your reply. The man we're seriously considering has 14 years experience; plans to sand, stain and apply 2 coats of oil-based poly. The thing that concerns me the most, though, is that I read where Bruce engineered floors have varying degrees of thickness. How do you know how much to sand? Should I question him specifically about his experience with engineered floors? Thanks for your help!!
Old 09-23-2009, 06:15 PM   #4
WaldenL's Avatar
Most certainly! Engineered hardwood floors have a thin top layer, and you can sand right through it and ruin the piece. Per the Armstrong site (makers of Bruce) "Engineered wood with a top layer thinner than 1/10" cannot be refinished; however, it can be recoated to renew the surface of the floor." Make sure this guys knows he's not dealing w/a solid hunk of wood.
WaldenL is offline   Reply With Quote
Old 09-23-2009, 06:54 PM   #5
Building codes guy, Mod
thekctermite's Avatar
I too would have major concerns about the thickness of the wood veneer. It would be so very easy to sand right through it, ruining the floor. Definitely worth a call to the manufacturer's tech people to get some guidance from them before you take the plunge.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 09-23-2009, 08:46 PM   #6
Engineered floors have 1/8 thickness. a little more than veneered (they are different). Keep in mind 220v sanders usually take off between 1/16-1/8 off a floor when it's already flat. Engineered floor reps claim that there floors can be sanded up to 3 times... thats really crap. Technically they prob could if sanded just barely enough to strip off old finish and if there weren't any dings on the floor. I'd say you could get away with sanding it once. I had a salon that had thousands of heel mark holes in engineered and there was no way to sand them out. 2 coats is not enough to withstand wear, he should be putting down 3 or be giving you a discount for not.
Old 09-23-2009, 11:10 PM   #7
Great info FloorGuy!
Old 09-25-2009, 02:15 PM   #8
Floor Guy
You wanna use either DuraSeal or Bona Hardwood Finishes. simply the best.
Alessandro is offline   Reply With Quote
Tags
flooring advice, refinishing hardwood, waterborn poly
More On This Topic
Hard wood floors are also stained pretty easily. The first thing you can do is use a number two steel wool; this is the softest steel wool that you can find. And you’re going to dip that in a paint thinner and rub it over the stain a little bit... Read More »
Parquet floors are beautiful in the home but require a lot of work. They may not be the best option for those with small children or dogs. If you do choose to have parquet floors and a dog, train your dog well to prevent any messes on beautiful wood... Read More »
Okay! Now that we know a little bit about the sanders, we need to talk about going through the grits. What I mean by this is that we are going to progressively go from a courser sandpaper to a finer sandpaper throughout the process. The grit refers to... Read More »
Hi! My name is Jennifer and I have over 10 years of wood working experience and I am a general handyman. What we have been doing for the past couple of steps now, is we have been sanding down this bench here to prepare it for some refinishing and some... Read More »
Cork, a renewable resource, comes from the bark of the Mediterranean cork oak tree. Every 9 to 10 years, cutters carefully harvest cork bark without harming the host trees. Through a process of grinding and baking, craftsmen create cork flooring sheets... Read More »
Need help choosing siding chuckcrimson General Discussion 0 08-04-2009 04:36 PM
Help choosing siding chuckcrimson Building & Construction 0 07-27-2009 10:40 AM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 11:19 AM
choosing right bulb and trim kit combo for recessed windowguy Electrical 2 02-09-2009 01:17 PM
help with choosing color elapie1879 Interior Decorating 4 11-03-2007 11:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
