Choosing Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 10:26 AM   #1
Question
choosing carpet
Nylon vs polyester??
The carpet we have picked out for our entire house is nylon. We have cats that sometimes puke. Cat puke is the hardest stain to remove without a doubt. Is nyklong for us?
Also, we have chosen Mohawk brand. Your advise or comments on Mohawk are appreciated.
Also, we have chosen Floor Trader. Same...comments or suggestions??
THANK YOU!
P.A. is offline   Reply With Quote
Old 07-29-2010, 10:58 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
All carpet mills make different grades of carpet. When you figure price and quality, nylon is your best buy. Never buy because of wear warranty, nylon doesn't wear. It uglies like all carpet. Wool is a better fiber, but too expensive to allow the cats to get sick on. Polyester is cheaper, but will mat worse than nylon.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-29-2010, 03:51 PM   #3
100% correct above
i own a carpet cleaning business and have a few thoughts
1. you do not want wool, it's harder for us to clean and relies on the treatment for stain resistance. if you're really clean with no pets this is great carpet
2. quality nylon with a good factory stain resistance treatment is golden with animals. when you do have your carpet cleaned the prespray should be a ph under 10. the really aggressive pre sprays will kill the protector. also, every year or two having the cleaner re apply protector will make stains MUCH harder to set in the carpet.
racebum is offline   Reply With Quote
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
