Children Friendly Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 09:07 PM   #1
Post
Children friendly basement
Hello all,
We had a finished basement we use as a play room for the kids with wall to wall carpeting. Then hurricane Irene blew thru and our basement became flooded. Needless to say the carpeting is ruined! We originally chose carpeting with a thick padding because our 4 children can play wild at times and would absorbe a fall and we could avoid an ER trip.
So now we are forced to consider new flooring and we would like some suggestions for children friendly flooring but minimum clean up or damage should another flood occur. All suggestions are welcome!!! Thanks!
Massirk is offline   Reply With Quote
Old 08-30-2011, 04:29 PM   #2
Taking stuff apart is fun
Bummer 'bout the flooding. Hope everyone was OK.
Not at all trying to hijack the thread but how did you like the carpet? I'm also finishing a basement for our first child who is due in December. I'd like something easier to clean up in case of water but carpet seems to be the most kid friendly.
butchbs1985 is offline   Reply With Quote
Old 08-30-2011, 04:40 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Carpet is really the only thing soft enough for kids. IMHO
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-30-2011, 05:06 PM   #4
the Musigician
DangerMouse's Avatar
Cork is soft....
DM
Old 08-30-2011, 06:12 PM   #5
DIY staff
Rewards Points: 7,174
A good solution is a thick rug and pad over a water safe floor like ceramic tile---etched concrete or even paint.
Nasty weather and you can roll up the rug--If it does get wet you can send it out to be cleaned properly.
ttr13r (09-05-2011)
Old 08-30-2011, 09:26 PM   #6
TimAllen37's Avatar
just get a new thick carpet
TimAllen37 is offline   Reply With Quote
Old 09-04-2011, 08:17 PM   #7
I have a friend that bought these interlocking foam squares the top is made to look like a hardwood floor. She put them in her basement playroom and they are warm to walk on and quite squishy. They are just like those dense foam mats they put down in gyms and stuff. Anyway her basement had water get in and she took apart the floor since it was just those foam squares cleaned and dried them and put it back down again and good as new. Looks pretty good but it does dent in if you put something heavy on it. looks like these http://www.rubberflooringinc.com/interlocking-tile/foam/soft-wood-tile.html#ProdDetail
mommiemara is offline   Reply With Quote
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 03:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
