Check If Floor Is Flat - Flooring - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 07:44 AM   #1
bryanp22's Avatar
Rewards Points: 294
Check if floor is flat
What is the proper method to see if a floor is flat? I'd don't need it level just flat. This is my concrete basement floor. If I get concrete flooring patch any recommended brands or application methods?
bryanp22 is offline   Reply With Quote
Old 08-26-2013, 04:28 PM   #2
DIY staff
Rewards Points: 7,174
Ardex Feather finish is a good trowel on patch---
If you have a large area a self leveling compound might be the answer---it is to soft for walking on---but is ideal under carpet/tile/laminate--
I use an 8 foot straight edge---and chalk---
Old 08-26-2013, 04:37 PM   #3
bryanp22's Avatar
Rewards Points: 294
I didn't think SLC was an option because my floor has a slight slope towards the center and I just have a few spots that are low.
Old 08-26-2013, 06:00 PM   #4
DIY staff
Self leveling compound might be a problem if there is to much of a slope---try the Feather Finish----It is available at the Home Depot---
Old 09-01-2013, 01:55 PM   #5
Rewards Points: 274
Feather Finish would be fine and appropriate.
alexjoe is offline   Reply With Quote
Old 09-01-2013, 07:28 PM   #6
Retired & Not Likin' It
Jim McClain's Avatar
The standard for flatness is 3/16" in 10 feet. You can get a cheap, 10' piece of angle iron or similar from your local hardware store.
You didn't say what type of flooring you were going to install, so recommendations of specific products is premature. Ardex Feather Finish is a very nice product, but if you are installing a floating floor, the vibration might be enough to break up the patching compound. You might be better off using layers of 15# felt or some other appropriate material.
Jim
Jim McClain is offline   Reply With Quote
Satin or Flat for Exterior Paint Sheen?? Which is most durable/protective? DamonBoost Painting 12 06-17-2015 07:28 AM
Flat Roof - probably not DIY for me mymrbig Roofing/Siding 13 02-26-2013 05:31 PM
seeking skilled Roofer for Flat Roof House beesandsac Roofing/Siding 5 10-22-2012 01:56 PM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
