Cheapest Thinset For Backerboard Ok? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 10:25 PM   #1
Rewards Points: 117
Cheapest thinset for backerboard ok?
Hi all,
I'm looking to tile my floors that has plywood subfloor. I will be installing backerboard underlayment for the tiles (marble). To adhere the backerboards to the subfloor, is it ok to use the cheapest thinset I can find as shown here?
http://www.homedepot.ca/product/cust...y-50-lb/921779
The product description only mentions this for tiling over concrete (no mention of plywood), so maybe it may not adhere properly on plywood? However, I heard that thinset under backerboards is mostly just to fill the potential voids.
Will this thinset be ok for laying the backerboards? Thanks!
jsunsun is offline   Reply With Quote
Old 08-26-2013, 11:35 PM   #2
Remodeling Contractor
THe difference between Custom and Versabond is about 10 bucks a bag. Use Versabond for both the underlayment and your tile
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
Old 08-27-2013, 12:00 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 288
Hi guys,
It's generally accepted that you can use a cheapo unmodified thin set for under concrete backers, but some want you to use modified. What brand backer will you be using?
You may not know, (?) but natural stone tiles require a much stiffer subfloor system than ceramic tiles do. I'm betting your subfloor is probably gonna fail minimum requirements. Just a wild guess.
Tell us how the house is framed, type and size of joists, species and grade of joists would really help, joists' spacing, unsupported span. Also need to know the type, thickness and number of layer that make your subfloor/underlayment before any tile backer.
Jaz
Old 08-27-2013, 12:33 PM   #4
Rewards Points: 117
The backerboards I'm using are called Wonderboards. The instructions made no mention of what type of thinset is required, it just says "apply mortar..."
Regarding whether the floors can support marble tiles: The subfloor boards are 3/4" thick. The joists are 2x10s, spaced 10-11" apart. Some parts of the floor have 2 ply 2x10s. The longest unsupported span (I-beam to exterior foundation) is 14 feet. I have no idea what type the subfloors and joists these are, but attached are images if that helps. Amongst all the houses I've "stomped" on, this house definitely feels amongst the most solid. Almost as if I'm stomping on concrete.
Old 08-27-2013, 09:01 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 288
Hi Sun,
Actually you must have missed the directions. http://www.custombuildingproducts.com/TDS/TDS-266.pdf
Use a polymer-modified mortar meeting ANSI A118.4 standards, such as FlexBondŽ Crack Prevention Mortar, for leveling bed and joint treatment; mortars meeting ANSI A118.1, A118.4 or A118.11 adhesive can also be used.
So it sounds like you're saying the unknown species and grade of the 2x10" joists are spaced 12" o.c. there are some joists that are sistered, and they span 14' 0".
It's not clear whether "the subfloor boards" you refer to are 3/4" planks or the plywood subfloor. It sounds like you meant the subfloor are 3/4" planks and there's 3/4" plywood over them. So, do you have two layers of subfloor? If so and they're in good condition, that's a good thing.
So to sum up; if my assumptions are right, your subfloor should be stiff enough for natural stone tiles if installed correctly and still in good shape. The framing seems a little shy of min. specs but I can't say for sure without knowing their species and grade. I think you're very close if the joists are grade #2 and the species is Southern Pine. If everything else was fine, I'd do your install, but I would stress there would be no warranty against cracking due to subfloor deflection.
Jaz
Old 08-27-2013, 09:21 PM   #6
Rewards Points: 117
Thanks! I didn't know there is a more detailed instructions other than what is on the board itself. I guess they do want a modified thinset, so I guess that rules out the cheapo thinset. Thanks all!
Old 08-27-2013, 09:29 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 288
They prefer a modified mortar but you can use a cheapo unmodified meeting A118.1 Be sure to follow instructions about the bond breaker tape over the subfloor seams and be sure to use the correct mesh tape for the CBU seams.
It sometimes isn't worth getting two type of mortar cuz you're likely to have partial bags left and the savings may not buy you a happy meal. Now if it's a large job, then.................
Jaz
Old 08-27-2013, 10:18 PM   #8
Rewards Points: 4,792
Look at his picture, which implies the subfloor boards are solely 3/4" plywood.
jeffnc is offline   Reply With Quote
using recently mixed thinset with newly mixed thinset DiyCR fan Flooring 6 03-19-2013 09:19 AM
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
