Cheapest Floor Possible? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 11:39 PM   #1
cheapest floor possible?
looking for some input on how to make cheapest garage floor possible. it needs to be a hard and flat surface to support a vehicle and easily roll my creeper. that fancy concrete is too expensive. dirt too soft. thought about putting moisture barrier over a well compacted clay/pea gravel base then placing plywood over that. but wouild still be astronomically costly for a broke coonass. any suggestions?
brokeasscajun is offline   Reply With Quote
Old 02-23-2013, 11:47 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
If you can't afford concrete.....then you can't afford anything else that will meet your stated requirements.....you would be better off in the yard.....or go down to your local Wallmart and use the parking lot like everyone else does.
Old 02-24-2013, 12:04 AM   #3
Rewards Points: 6,652
Go look at the German House Rebuild thread over in the Project Showcase. ShumakerScott used crushed stone under a vapor barrier, then laid OSB over the top of it to create the floor.
Old 02-24-2013, 10:16 AM   #4
Rewards Points: 236
perhaps you could find a bunch of used paver blocks on craigslist.
Fix'n it is offline   Reply With Quote
Old 02-24-2013, 10:19 AM   #5
Rewards Points: 236
i just checked my area. that are a bunch of listings.
Old 02-24-2013, 10:25 AM   #6
Floor Installer
sam floor's Avatar
Rewards Points: 154
A mechanic's creeper won't roll very well on paver blocks.
sam floor is offline   Reply With Quote
Old 02-24-2013, 10:41 AM   #7
"you would be better off in the yard."
Working on vehicles 35 years in the yard, no garage. I have a 4'x4' plate of steel for the floor jack and two 1" plywood squares for jack stands.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
sam floor (02-24-2013)
Old 02-24-2013, 02:02 PM   #8
Rewards Points: 236
no, it won't. but he did ask for "cheap". he could grout smooth the pavers.
Old 03-11-2013, 11:28 AM   #9
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
here poor people go to the riverside and extract stones and use that for their houses. I think this is your cheapest option
harrymontana is offline   Reply With Quote
Old 03-11-2013, 09:58 PM   #10
Rewards Points: 960
cash in that creeper for a piece of cardboard like I use.
cleveman is offline   Reply With Quote
Old 03-11-2013, 10:15 PM   #11
Rewards Points: 83
pour a slab just where you need it with sak-crete from home store.
form up a square drop in some chicken wire and start mixin'
mech_gui is offline   Reply With Quote
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 10:18 AM
cheapest place to buy retrofit windows sacseven Windows and Doors 12 12-29-2011 10:29 AM
cheapest way to heat garage evansj24 HVAC 2 08-28-2011 11:39 PM
