Old 08-18-2012, 10:30 PM   #1
Charcoal Color Grout is White on Shower Floor
New to the site, but already have found some great information.
I just had my bathroom remodeled including the shower. I used sanded charcoal grout on my shower floor with gray flat stones (believe the stones may be some type of marble, but not sure). The floor was sealed with Miracle Sealants Seal and Enhance.
After a few days, the grout has turned light grayish appearing hazy white. See photo.
I tried Aquamix Nanoscrub to try and "remove" the haze color and get it to be the dark charcoal color I want. It worked a little bit, but not very much.
I've been reading that a 50/50 mix of vinegar and water might work, but I'm concerned it would damage the stone. Will it?
Any thoughts/solution suggestions? Your input is greatly appreciated as I really want to fix this. Thank you.
jrent is offline   Reply With Quote
Old 08-18-2012, 10:37 PM   #2
Vinagers not going to hurt it.
Old 08-18-2012, 10:53 PM   #3
try the 50 50 mix won't hurt use a course rag to remove haze..
Old 08-19-2012, 10:06 PM   #4
Thanks for the replies. The vinegar didn't work. Which product can I use to remove the sealer but at the same time not damage the stone on the floor and surrounding marble? My plan is to remove the sealer and try aquamix "enrich and seal" next.
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 10:03 PM
Fixing a poorly sloped shower floor. Need some direction please. SteveMegg Tiling, ceramics, marble 2 05-12-2012 11:18 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
