Old 05-23-2008, 10:31 AM   #1
Change from carpet to hardwood stairs would make it safer?
Our house has a nine foot ceiling first floor. But the stair to go to the second floor is one straight type, no turning....
I should have not picking this style knowing this is a big dangers design....
this morning... wake up at 6 am to go to the backyard to do my digging... got sliped on the stairs (when my feet is still not to strong you know 6 am).... and almost hurt me badly.... make me hate this stair even more....
can I do somthing to help a little bit... : by changing from carpet to hardwood... or wood stairs even more dangers... I am thinking is would be less slippery...
any experience sharing?
KUIPORNG is offline   Reply With Quote
Old 03-25-2009, 06:16 PM   #2
I had it done.
priestess is offline   Reply With Quote
Old 03-25-2009, 08:45 PM   #3
Generally wood steps are the most slippery of all types of steps.
Also, if the steps had carpet, then they probably have lips and gaps that need to be dealt with in order to put on wood. It can be expensive to modify them for wood.
I've looked at a number of staircases that had carpet and the customer wanted wood on them and there have been times when there were complications that made wood unfeasible.
Mudd is offline   Reply With Quote
Old 03-25-2009, 08:53 PM   #4
Floorwizard's Avatar
Wood stairs will not help at all.
best to wear grip slippers...
Floorwizard is offline   Reply With Quote
Old 03-25-2009, 08:56 PM   #5
Smile
Hi,
Trying to replace stairs.....need oak riser and treads.
sandi64 is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
