Ceramic Vs Porcelain - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 01:20 PM   #1
Question
Ceramic vs porcelain
I have never attempted laying tile. I read alot about it and decided on using porcelain. A friend told me it is hard to cut. Is this a problem with porcelain?
wrecklifter is offline   Reply With Quote
Old 02-17-2011, 08:06 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
First, understand that porcelain tile IS ceramic tile. The recipe used to make it is slightly different from what is used to make standard ceramic tile.
Porcelain has a greater density (therefore less absorbency) than standard ceramic (basically) and is therefore somewhat harder to cut.
The same saw (blade) or tile-breaker that you use for ceramic will in most cases (not all) also cut porcelain.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
wrecklifter (02-18-2011)
Bathtub Porcelain Enameled v. just Porcelain amgdiy Kitchen & Bath Remodeling 13 10-12-2010 09:48 PM
Polished porcelain - Executive decision needed!! kaciuba Flooring 9 06-04-2010 02:27 PM
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 01:46 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
Ceramic vs. Porcelain satchmo Flooring 11 07-19-2007 12:05 AM
