Ceramic Tiling On A Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2007, 09:10 AM   #1
Ceramic Tiling on a Slab
I'm planning on tiling my lower level bathroom that is on a slab (Quad-Level Home). Do I need to lay any backerboard down or should I be able to just tile on the cement slab?
nsb318 is offline   Reply With Quote
Old 02-26-2007, 12:52 PM   #2
ditra seems to be a good choice
Although I cannot tell from experience as I just using it yesterday... but after I did all research... ditra seems a good choice....
laying direct is the cheapest way of doing it, and most contractors do I believe unless home owner asked for it in particular... why would they cost more to do it for you to cut their profit...
but ditra seems built to last...
KUIPORNG is offline   Reply With Quote
Old 03-01-2007, 12:08 AM   #3
Floorwizard's Avatar
red guard anti fracture membrane is a possibility.
Floorwizard is offline   Reply With Quote
Old 03-01-2007, 03:23 AM   #4
No backerboard on cement. You can tile directly to the cement if it is in good condition: no paint or other residue, no cracks and cured.
Rich
Remodeling is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
