Old 11-20-2008, 12:28 PM   #16
ceramic tile to wood floor threshold
the wall may expand and if you butt the tile right against the wall or framing it may cause the tile to move
mattedfred is offline   Reply With Quote
Old 11-20-2008, 01:45 PM   #17
Floorwizard's Avatar
Ahhh yes.
I did not think of that.
thanks.
Floorwizard is offline   Reply With Quote
Old 11-20-2008, 08:53 PM   #18
Tileguy
Bud Cline's Avatar
EVERYTHING expands and contracts, EVERYTHING.
Install ceramic tile on a wood substrate in a south-facing room with plenty of sunlight....the potential for disaster is tremendous.
Florcraft if you get Tile Magazine (Nov 2008) read an article by Dave Gobis in that issue you may learn a thing or two. It may be online also.
Old 11-20-2008, 09:26 PM   #19
I do not install over wood without Ditra or something that will keep expansion from affecting the tile.
But I get what you are saying...
thanks.
Old 11-20-2008, 09:46 PM   #20
Tileguy
JazMan's Avatar
Installing over Ditra does not eliminate the need for expansion joints around the perimeter OR in the field if the area is large enough.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 11-28-2008, 10:13 AM   #21
If you install hardie over underlayment with modified thinset, doesn't the thinset fill in the expansion joints that were between the underlayment seams? I'm getting ready to do this and I have a tile job with a southern exposure getting alot of light from a patio door. Thanks for all the great info.
tishimself is offline   Reply With Quote
Old 11-28-2008, 05:22 PM   #22
Tileguy
Bud Cline's Avatar
Not if you caulk the seams first.
Old 11-28-2008, 06:57 PM   #23
Tileguy
JazMan's Avatar
You should treat all the seams, (subfloor, underlayment and CBU as directed by the thinset and CBU manufacturers. Some want you to keep thinset out of the underlayment seams, while others want you to fill them. Filling those seams will not necessarily prevent those seams from compressing, they will compress with latex modified thinset in there.
You're still supposed to install expansion joints in the field in all installations if they're large enough or under certain conditions such as direct sunlight and wet rooms. Expansion joints are placed in the CBU and directly over it in the tile.
Until a few years ago Hardie used to tell us to install an expansion joint in the center of any room both ways if the room was 15 ft. or larger in any direction, and where the room makes an "L". This was rarely done since most people didn't have or didn't read the directions anyway. Today's directions don't even bring up the subject of field expansion joints. Touchy subject I'm sure.
tishimself, that type of installation requires additional joints every 8-12 ft. in both directions.
Jaz
Old 11-28-2008, 09:35 PM   #24
Home Imp./Remodeler
bjs,
To get back to your original question, as Bud said, you should tile to the center of the door jamb. Rather than a grout joint here, leave approx. 1/2" space and install a nice piece of T-molding or some other transition piece. Also, make sure you undercut the jambs with an undercut saw. Stack a piece of underlayment and a tile on the floor next to the jamb and rest your saw on this as you cut. This will give you a perfect height cut under the jamb that you can slide your tile under. Gives it a finished professional look.
Good luck!
Dan V. is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 08:46 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
